Headlights in oven
    Headlights in oven
    has anyone did oem headlight with plastic lenses. If so how long and what temp?
    -thanks
    stockies?!?!?
    I think its 275 for 10 mins??
    I might be wrong.
      CD .. so its not glass like a cb.. Just place them on the rack ?
        what you put them in the oven for?
          make sure the plastic isnt touching any metal!
          a little quicker and less labor than using a heat gun.
          Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
          -(B-Pillar Bar Originator)-
            Ahh yes 5th gen lights....
            275 for 10-12 mins is good i believe, but always monitor them and ive heard that with plastic you could put them on like moist towels to keep from melting the plastic.
            Just be carefull as theyre not glass.
              i did 225 for around 8 mins.
              FA1
              355
                200 until its gooey
                wat?
                  i just did mine with a heat gun last weekend... even in some spots the plastic didnt look so healthy with the heat gun so i'd be careful with the oven
                    200 for 10-12 mins and you can pry them apart with a flat screw driver. Make sure that you take the adjustment buckets, the clips, and the bulbs off also before baking the lights.
                    the lenses are polycarbonate and 200 degrees shouldn't do anything to them, just make sure they are oil free. I did my 2001 Focus headlights myself and it worked great.
                    Check out ESP engine mount kits for your CB7!!!
