My car drinks its oil capacity about every 500 miles, and I've found this hole about an inch and a half below the oil filter that has nothing at all in it. A mechanic who hosed it down with brake cleaner says that the motor stalled if he hit that spot, so apparently it's getting vacuum...?
I found this picture in someone else's thread, and I can't tell if that's just a plug or a sensor of some sort, but there's absolutely nothing there on my car and a ton of oil is leaking through it. To be clear, this isn't the oil pressure sensor, which is right above the filter. I have one of those, it works.
