just the title says i installed the end pistons... after i torqued the rods down, i tried to turn the crank by hand but the crank isnt turning... but when the bolts are just tighten(not torqued) the crank can turn... i used 35ft lb or torque on the rod bolts... i have an F22a motor...the connecting rod bearing are honda bearing, straight from the dealer ship...they are same as the original bearings...
my buddy suggested that i should install all four pistons first before torquing the rods, then try turning the crank...but says its a wierd problem...
need help ppl...let me kno u guys or gals need pics or vid...
