Well...i was driving around today (1993 Accord) and i hit a little bump going about 5mph...and got mad and revved up my motor...and it started to make a whining noise..i pull over on the side of the road to see where its coming from and it sounds like its coming from the alt or the ps belt im not sure. When im driving it and i give it more gas it gets louder...it almost sounds like that noise your speakers make...kinda high pitch but not..what do you guys think it is? Im thinking about sparying some wd40 on the belts or maybe one of the belts is loose/tight. But i dont know.
Whining noise from the belts...
Originally posted by LX Rida
damn...just sprayed some wd40 and its still making the noise....you think a bad alt would make that noise??
mine was the belt tentioner wasnt that tight...What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Bump for the same problem: Began after going over speed bump at apartments. Next morning there is slight whining coming from Acss. area. Looked at the timing belt (literally just to see if it was in 1 piece, i have no idea what I would be looking for) and its still on the gear.
BTW the whining PULSATES. Help is very appreciated!
- ZipcreatureLast edited by zipcreature; 08-22-2005, 02:22 AM.
Originally posted by DirtySouthHondaActually, my CB7 makes the same noises. I had my car fixed by a mechanic and when i got the car back, i heard some kind of grind and a high pitch noise when I revved my engine. It's still doing it and the high pitch I can hear when I drive.
How do I tighten the belts?
PS When I look into the timing hole, I see that the flywheel is over to the far left side - and there is a gap of about 1/2 inch like this : [I: >I]
Any ideas?
- Zipcreature
