Broken stud header related
    So i'm in my garage starting up the car since it's been a few days. I'm up in front of the car looking into the engine bay when i notice a small area of where the gasket behind the header it seems to be leaking a very small amount of oil. I tighten the nuts around where the leak is but end up snapping one.
    It doesn't leak oil just to the right of where i snapped the stud anymore nor does it smoke or anything. It's just broken and an eyesore. Can this be repaired?
    You'll have to get a pair of vice grips or a bolt extractor to take it out once you remove your header. You can find the studs easily at junkyard.
      oh good so i'm not fuxored then.
      well i was hoping i wouldn't need to remove the header to install it but oh well. Better do it the right way so i don't ****ed myself again.
      Thanks for the quick reply man.
        or you can get one from the dealer for around $2-3..
          should be easy, there's a little bit sticking out of the head.
          I <3 G60.
            looks like an easy fix i had one snap off flush with my head befor so i had to drill it out then get a bolt extracter and remove it and rethread it for the new stud ... you can get packs of them from the parts store too
              thanks for the re-assurance guys. this just popped into my head but should i also use a thread lock of any kind? when i go to install the replacment?
                if theres enough thread you could try taking it off by putting two bolts on top of eachother
                Meh, not feeling the honda game anymore.
                MY CAR IS SOLD!!!
