egr problem
    egr problem
    lately i have been getting a CEL when it's hot outside. i checked the code it came out to be code 12. i have a mitchell manual and i performed all the tests on the car but still the egr keeps throwing up cells. anyone have any ideas what else could be wrong ? the car doesn't run too bad but i don't like the cel there
    block it off on the manifold and zip tie the valve & sensor to the firewall with the vac line and wire connector still plugged in...
    RIP Lifsatrip7
      tap the egr diaphram..it will go away...for a bit...
      there is a diy on cleaning the egr ports search for "cleaning" in the DIY forum
      Retro!
      Hater
        all those have been done in the spring before the problems started occuring on a daily basis. i think it might be the relay that when it is warming up it is acting stupid.
          it shouldnt be, check for vacumn leaks at the egr...see if the egr valve is funtioning properly...
          Retro!
          Hater
