battery drain
    battery drain
    what should i look for?
    What you say?
    wat?
      Originally posted by C91BLX7
      What you say?
      something keep draining my battery...better?
      i took battery to test and still good..just low..
        Do you have a amp?
        wat?
          Do you have a amp?
          no......
            so no one got no idea how the battery got drain...
              Could be the alternator. Do this. If you can start the car, while its running, take off the positive terminal from the battery. If your car dies immediately, its the alternator. If your alternator is bad, you're running off straight battery. If that's not the case, check the connection between your battery and alternator. That might be loose. Lemme know how it goes.
              Follow me on IG: @jdm_inspired
              93 'til infinity
                Also you may have a short. Theres a way to test that. I'll tell you in detail if what I told you DOESNT work but its a looooong process and requires 2 people.
                93 'til infinity
                  Finally somoeone respond..boy i thought no will never:
                  I'm not so sure...Cuase alternator is pretty much new..But i will give it a try first thing in the afternoon...since now is like 2:30AM
                  i'll let you know
                    Haha, do it now. LOVE your car. Haha jk, keep me posted.
                    93 'til infinity
                      at first i thought battery was dead...but i notice that the battery was not even a year old yet..so i took to Autozone to test..battery is low..Charge and good to go..
                      park car for few days..same thing happen again..
                      as said..i'll let you know..
                        I sure love too but car is outside in the cold...
                          hey man..car still doing that?
                          Originally posted by jhondayaaj
                          too bad seattle silver's are the best.
                          ACCORD MEET MAY 29th 2010
                            I had somewhat of the same problem. Check the alternator belt. If its loose it wont charge the alternator. Mine was "filleted" said the shop. That caused mine dilemma. Check that too. Make sure the belt is in one piece and in good condition.
                            93 'til infinity
                              hmmm......never thought of that.....
                              thank you...I guess you're the only nice guy tonight..
