help, car has no spark.
    okay, since everyone here are pretty much mechanically incline I thought I can get some help on a friends car. her car has crapped out on her, she has a 95 dodge stratus, her car is the type that doest have a cap and rotor. so she is not getting any spark on all 6 cylinders. engine turns over but nothing, strong fuel smell, I checked everything else and its fine, fuel pressure, timing, compression, fuses, spark wires and plugs, so its pointing at the distributer. anyones help is great.
    did you check the power to the coils? i could be a ecu problem to. i know we worked on a status once that didnt get any spark. changed the ecu, and it fired right back up.
    miss my turbo cb7
      has the thermostate been changed latly? if so check the ground thats connected to the thermstate housing thats the ground for the ecu and if thats not grounded then you wont get any spark. if that doesnt work the most likly the distributer.
        it's a dodge............
        possible bad crank sensor.
