My bro has a stock 93 10th A.E. The problem we have is the car cuts out after about a two mins of running, if sat overnight. After it cuts out it won't start back up again, it gets spark because it starts like I said, also it was tuned up a few months ago. The fuel pump does prime but you can faintly hear it. It is probably not a main relay/ fuse problem because I do have power to the fuel pump. Also, ignition system/ distributor works as it should.
My question is, is it possible the fuel pump is on its way out and is giving out low psi/ very little gas? Does this sound like a fuel filter problem?
Let me hear your feedback, if you ever experienced this or think you can help us. I need this car going asap. Also if the fuel pump needs to be changed, is it necessary to drop the tank or can i access it through the trunk behind the back seat.
