Hi everyone, this is kinda specific. I have A JDM H22 in my 92 EX, everything that I can think of is hooked up, but its not turning over. Now when I turn the key to the ACC position I dont get a CEL check, and when I go to the Start postition the brake and ABS lights go solid while I hold it on start. I can here some relays clicking somewhere, no fuel pump tho. Im gonna guess grounds. I also relocated the battery to the trunk. So I have the power and fuse box wires going straight to starter. Ground in trunk, ground on the block under dizzy, and ground on valve cover. am I missing anything? I love you guys
H22 wont start
lol this dood..."i love you guys"
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
well it hasnt ran since I put the H22 in it. Im thinking the same with the grounds. I think we are talking about the same ground. Right under the dizzy, it may be screwed into the tstat or the block i dunno. ill check those tmrw. im working nights, so I have some time to mull over it.
And the I love you is added motivation to get this thing going, I really do love you guys Im not IN love with you tho anything else would be appreciated, i want this bad mofo runnin!!
Do you have a test light? You can have someone else try to start it while you test for power at the starter and around the fuses. You're battery is charged up, right? If it isn't, then it will just make a rapid clicking noise as well. Also double check that you tightened the clamps on the terminals.1992 Prelude S w/swapped H22A
copy that i had a starter problem with my 93 and thats what I did to fix it. ill try that. A grounding block sounds good, we just got dumped on with snow, so it may be a while before I get back out there. My battery is good, I grinded a spot under the carpet and attached the ground there. Does the ECU have a specific ground, it seems like the problem is around there cause its just not giving me any CEL or warning lights when I try and start it.
Ever think of checking the starter?
Unless it turns over but fails to start...then that would be a different issue.
:ninja edit:
What year is that motor? Because if it happens to be an OBD II motor then you need to change a few things in order to make it properly work.Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
