no spark what so ever
    main relay
    GOT BOOST???
    massive part out on accord almost everything is going
    http://www.cb7tuner.com/vbb/showthread.php?t=125294
      going to buy a new coil and spark plugs
      my whipp
        you need to get your dvom or power probe and check for power and ground. follow your diagrams. if you need the factory honda prelude manuals with wiring diagrams pm me with your email address and i'll send it to you. i have it in pdf format. but you should be able to use your haynes and follow those diagrams cuz you probably used your factory harness and unless you re-wired the whole car it will be the most accurate. however the factory honda manual has troubleshooting flow charts that would help you out and describe step by step
        My other ride is your ex-wife
          do not start throwing parts at the problem until you have identified it correctly
            ok thanks
            my whipp
