When timing a h22 with the h23 manual tensioner conversion done, the belt is very tight and a real mother to get on. Now for the dumb part. Is it possible to use h23 cam gears (on h22 cams) h23 crank gear and h23 water pump and of course h23 timing belt.
The gear ratio of the crank rotation to cam rotation is 2:1 as long as the matching set of gears is used. Just wondering if anybody has tried putting h23 cam gears on a h22 cam.
