whats up guys i hav a prob. i hav a 91 with a jdm f22b been having it about six months now. the prob i am having is that i cant stop it from running super rich and having bouncing revs and dieing at red lights or if idling to long. ive changed everything such as main relay, dizzy,rotor,cap,plugs,wires,map,ecu,pt3, pt6,egr,o2 sensor twice,new cat, 2"1/2 cat back,iac,pcv,tps set at 5v,cleaned all ports (dosent matter still run rich so it black again),fuel filter. i'm thinking my injectors or my resistor is bad and i might need a new throttle cable. but other than that the only code i get is a o2 sensor code bought a new one put it in code went a way until i hit wot then cel comes on again.i'm using stock wiring no cuts or hacks in the wires. it doesnt stumble while on the freeway it just runs way to rich. you can get out the car and smell almost strait gas but there is no leaks no where. i think it might be my injectors or reistor box. what do yall think. trying to get it to run stait before turbo goes on.
got probs need opinion
What kinda of o2 sensor are you running? Bosch = no good. IF you want a good o2 either go OEM if you have the cash or NGK/NTK.
