Ok guys heres the deal!! Car is a stock 98 Honda prelude!
Im installing a JDM DOHC F20b in it.
I was going to splice the CKF and CKP wires so i can run the F20b without swapping in a USDM oil pump with CKF sensor.
I went to splice the wires and for some reason my 98 prelude ecu harness is missing pin outputs c1 and c11 as if it were an OBD1 car.....My stock engine does indeed have the CKF sensor...
Here is where i need help. I tried to do the CKY CPS hack at the ecu found here
http://technet.ff-squad.com/ckftrick.htm
However i am missing pin c1 and c11 at the ecu pinouts and.... As i said, i swapped over the F20b internal dizzy for my 98 preludes h22 dizzy, which is an external coil. So using my stock prelude dizzy what can i do to bypass the crank signal? I will also be running an obd2a-obd1 conversion harness with a po6W vtec conversion and chrome pro.. Thanks again!!
