ok guys i swapped the f22a6 for the jdm h22a. the original p13 ecu i got was junk. so i got another one but for the time i didn't have the new p13 i used the pt6 for testing and driving within 1 mile of home. she ran fine with the pt6 just rich and no vtec of course. we have checked and tested as well as replaced every sensor and component like the map the dizzy tb, tps,fast idle, cold idle, iab, manifold pressure sensor, checked timing and re adjusted valve lash. she will idle with the p13 and then when given throttle with no load in nuetral she will die or bog down bad and then die. we also checked fuel pressure with two stock h22 regulators and an adjustable reg. but the thing that keeps kickin us in the nuts is it ran with no problems on the pt6. i have re-wired the knock as well as replaced it and re-wired vtec pressure and solenoid too. not sure where to go next. any suggestions would be greatly appreciated. if you can call me at 972-983-7155 or email or pm me. thanks
h22a swap help
What made the original P13 junk?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
As I recall something in the circuit board was burnt. He bought it off of ebay.
