.::THE JDM F22B Swap Guide::.
    i used gsr belt and its pretty loose.
      i'm currently using an H23 belt w/ the tension maxed out and it STILL has some slack... the GSR belt was IMPOSSIBLE for me to put on
      My Ride thread
      Flickr
      Originally posted by d112crzy
      And it can only get better. That's the best part.
      All I gotta really say is:
        well i guess its smaller how many teeth do think smaller the gsr is then the h23 is? and how amny ppl are running the gsr belt i just want to know before i go out and spend the money.
        Sold too: Grumpys93, '93CB7Ex, Bunta, prodh22accord, SSMAccord, fleetw00d
          Did you mill your head?
          There was no way the gsr belt was going to fit onto 91Accord-LX's f22b.
          The h23 wasn't incredibly loose. The tensioner made up for it.
            nope the head is stock except for the 3angle valve job and my car is 1990lx which i dont think matters. youve seen a video of my timing belt being loose and ive talked to u bout it too haha.
              i bought a gsr belt and its the same size as the one from my f22b when i got it its just a little wider by like 2 mm i hope it works
                ok well another failer the gsr belt i got was too small i cant get a break here but whayt i want to know now is what type of belt i need for the gsr i tried the 93 gsr belt but i here that the new ones like the 95'-98' works its justy a little wider what belt do i need the v-tech or non v-tech one?(the belt i got from the gsr just latly was like 4mm to short
                  gsr is vtec....
                  Have you tried an h23 belt? it WILL be loose, but the tensioner will take up the looseness.
                    yep i tried it and no the tensoner didnt help one bit was still 2 or so teeth to big
                      Wow.
                      the GSR belt was small for mine too.(2-3 teeth too small) So we put the H23 on and it was a little big (by about 1-2 teeth) but the tensioner took that out.
                      Everything is routed correctly and lined up?
                      I wonder if it's the tensioner maybe?
                      3 CB's gone....
                      1 WK Overland....
                      Still miss the CB though......maybe one day.
                        no the gsr belt was to small and the h23 was to big so im going with the 95-98' gsr belt but the width issue and rubbing is making me want to just get the h23 water pump they say that works since i already have the h23 belt and water pump is cheaper then the 95-98' gsr belt which at autozone is $44 i dont know what to do right now need to pick a side btw how long does it take to change out the water pump? and it fits right in right no mods needed?
                          I replaced mine with the F22A water pump. We held the two next to each other and they were identical. (F22B and F22A water pumps)
                          The F22A fit like a glove on mine. It wasn't too hard it took us like 30min. (but that was with 2 people)
                          F22B DOHC is pretty much a H23 head on a F22A block. I don't know if the H23 pump would work. But I have never heard of anyone trying either.
                          3 CB's gone....
                          1 WK Overland....
                            I THINK the h23 pump will bolt up, but the gear is different than the f22a's.
                              Do you remember how many teeth the f22b pump had?
                              I'm almost done replacing Junior's water pump, with my old F22B one.
                              I noticed that it had 19 teeth, compared to the f22a that had 20 teeth.
                              Everything else is identical tho.
                                Not off the top of my head no. I just remember you and I seeing they were pretty much identical.
                                3 CB's gone....
                                1 WK Overland....
