swapped the H22a wont start. used the noid tester for the injector plugs and theres no current gettin to the injector plugs. The motor's sparking and cranking over. Theirs fuel gettin to the rail just not gettin to the injectors cause theres no current gettin to the plugs.
. Stuck a flathead in the little thing under the dash on the pass. side to check the CEL code. blunk 3 times which is the Map sensor. could the Map sensor code be related to the injector plug problem?
![Confused](http://www.cb7tuner.com/confused.gif)
