Hey all,
I just bought an h22 swapped cb7 accord, threw my h23 trans on it with an exedy stage 1 clutch and fidanza flywheel. My problem was that when the car was warm it wouldn't go into any gear at all, like the clutch wasn't engaging at all. Then I pulled the slave cylinder and the previous owner rigged the slave piston so it would push farther out, as if to push the shift fork further and thus engage the clutch. I changed the slave and now it won't bleed because there is no pressure bc it doesn't reach the shift fork... Any suggestions?
Max
Max
