Originally posted by Torqstr
Have you ever dealt with the J-series?
Because personally, it is MORE compact than an F22, (an inch narrower by the time you account for intake and exhaust manifolds), which makes for MORE room in the bay than an I-4.
I can get behind the rear bank of BOTH of my mom's V6 Accords better than I could get around a similarly equipped 4 cylinder.
The engine doesn't weigh much more. It makes plenty of low end torque, and pulls all the way to the 7000RPM rev limit.
It is a significant upgrade in terms of power delivery, smoothness, and all around driving.
Having dealt with the king of straight sixes (BMW) it is every bit as smooth, powerful and sounds every bit as good with an exhaust system.
Not to mention this. Show me another stock Honda engine that will lay down 300+ WHP at 4.5lbs of boost.
And it gets better MPG, and BONE stock , a J30A5 will pull my mom's fully loaded EX V6 (3500lbs empty) just as quickly, if not quicker than my H22 swapped Accord.
And it will KILL my car on the highway.
Oh yeah. It's also an auto.
As long as the weights are even remotely similar, enough weight could be saved using other methods to offset the difference.
What little bit may remain could be taken care of in the suspension setup.
