I swapped a 96 honda accord ex vtec engine into my 90 accord, and i am using my same wiring harness and ecu from my 90 accord...but i have a knocking noise coming from my engine..i know its the knocking sensor...but i was wondering is there a way to hook the knocking sensor up without having to get a 96 ecu? Let me know if anyone can help....????thanks
ecu question???
im 99 percent sure those dont have knock sensors.. i believe only the DOHCs do..
second off you should be throwing a KS code..
third off, your vtec doesnt work...
fourth off, sounds like something is fucked in the engine...
fifth off- you cant hook up a knock sensor to an ecu that doesnt have a knock board on it..H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
i dont know all of them but...
p13=h22 ecu
p14=h23 ecu
p39=Jdm F22b ecu
Pt3-pt6=f22a1/a4/a6
p0a=f22b1 vtec ecu....
which you need.. but also is your motor obd2? im kidna thinking it is..H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
Code: OBD: VTEC: VTEC Cross-over: Rev Limit: Found In:
P05 1 no 1992-1995 Honda Civic CX
P06 1 no 1992-1995 Honda Civic DX
P07 1 yes 1992-1995 Honda Civic VX
P08 1 no 1992-1995 Honda Civic D15 (JDM)
P0A 1 no 1994-1995 Honda Accord EX
P0A 0 no 1990-1995 Honda Accord F22A
P13 1 yes 1992-1995 Honda Prelude VTEC (H22A)
P14 1 no 1992-1995 Honda Prelude Si (H23A)
P27 1 yes 1992-1995 Honda Civic EG JDM1600 SOHC
P28 1 yes 4500 7600 1992-1995 Honda Civic EX/Si / del Sol Si
p28 1 yes 1992-1995 Honda Del Sol Si/Civic Hatchback Si/ Civic EX
P2E 2 no 1996-1998 Honda Civic DX
P2M 2 yes 1996-2000 Honda Civic (NZ) SOHC VTEC
P2N 2 no 1996-2000 Honda Civic HX
P2P 2 yes 1996-2000 Honda Civic EX (D16Y8)
P2T 2b yes 1999-2000 Honda Civic Si
P30 1 yes 1992-1995 Honda del Sol DOHC VTEC EG/SiR
P54-G31 1 yes 1997 Honda Accord 1.8 LS (EDM)
P5P 2 yes 1996-1999 Honda Prelude (H22A)Type SH / Type S(JDM)
P61 1 yes 1992-1993 Acura Integra GSR (B17A)
P72 1 yes 1994-1995 Acura Integra GSR
P72 2 yes 1996-2000 Acura Integra GSR
P72 2 yes 1996-1999 Acura Integra GSR B18C
P73 2 yes 1996-2000 Acura Integra Type R (JDM and USDM)
P74 1 no 1992-1995 Acura Integra LS/GS
P75 1 no 1992-1995 Acura Integra LS/GS
P75 2 no 1996-2000 Acura Integra LS/GS
PBA 2 yes 1997-2000 Acura 1.6 EL (Canada)
PCT 2 yes 1997-2001 Honda JDM ITR/CTR
PCX 2b yes 1999-2001 Honda S2000
PG6 0 no 1988-1989 Acura Integra, All Models
PM5 0 no 1988-1991 Honda Civic/CRX DX
PM6 0 no 1988-1991 Honda Civic/CRX SOHC Si
PM7 0 no 1988-1991 Honda ZC (JDM EF)
PM8 0 no 1988-1991 Honda CRX HF
PR2 0 no 1988-1991 Honda ZC (EDM)
PR3 0 yes 1989-1991 Acura Integra XSi/RSi
PR3-J00 0 yes 1992 Acura Integra JDM B16A EF 8/9
PR3-J51 0 yes 1992 Acura Integra JDM B16A EF 8/9
PR4 0 no 1990-1993 Acura Integra LS/GS
PR4 2 no 1996-1999 Acura Integra LS/GS/RS (B18B)
PS9 0 no 1988-1991 Honda Civic 4-door EX Automatic
PW0 0 yes 1989-1991 Honda Civic/CRX SiR (or auto from 90-91 Integra XSi)H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
no you need the p0a ecu..
yup there is alot of shit you have to swap.. not only the wiring needs to swapped form obd1 to obd2....
and your distributor and injectors.. also need to be changed.
is your car auto? this might help
http://www.accordinglydone.com/forum...bd1+conversion
ebay www.car-parts.com yunk yard? other boards? i dont know manH22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
