Iv asked many similar questions about this and i just want to make sure what would be best.
I have a full h22 in the car now that has a warped cylinder. It has alot of blow by and has low oil pressure. It has never ran right from the start.
I recently purchased a full assembled h23a closed deck bottom end. It has some km's on it and i decided to rebuilt the h23 bottom end and put the h22 vtec head on it. Id be putting new rod bearings in, headgasket, rings and a hone.
I have done alot of reading and im getting mixed answers about it where ever i ask. the h23 should handle the same rpms as the h22 as long as i put the oil squirters in the h23 block.
My main questions is. Should i do the h23 vtec build or should i just take the h22 block thats in the car now, bore it .20 over and rebuild it.
The h22 block was boosted and i am almost certain one of the cyl walls is out of round.
The h23 block looks mint and from what i heard worked perfect.
i just havent done anythin lik this before and would like to make sure i do the right thing.
Thanks
Adam
Thanks
Adam
