my engine sucks please help
    so my engine (h22a into 93 accord) cranks but blows smoke out the tail pipe smells like gasoline. just sputters never runs smooth wont even stay at a steady idle just goes wom and spits a lil and then mixes those two noises together and blows smoke does anyone have a decent answer? please help
    check your o2 sensor, and air filter.
    92 accord lx sedan
    Phantom Grey Crew #6
    MY ACCORD
      Is your map sensor hooked up properly?
      mmmmmmmmmmmmmm....... DOHC
        kind of sounds like what my car was doing...you may want to check the spark plugs and make sure they arent immersed in oil due to a leaky valve cover. jmo
        93 Black Accord EX Sedan
        AEM Short Ram - Clears all around
        Gdzie jest frydryk???
          check your plugs and make sure you arent running rich? CAuse if ypu are your car is going to bog
            ok
            hey does anyone have pictures of their vacum lines hooked up on there h22a? and how about around the fuel rail and the fuel return line and the intake manifold front and back for the lines?i changed my plugs and got some nology hotwires stills runs like crap but im going to take off the distributor and turn it 180 degrees and try that
