I finally got my car to working and what we did is put a 93 accord f22a6 engine & auto tranny on my 91 and we had to use the internal dizzy from the 91 into the 93 and we changed the sparkplugs new filter. the idle runs low like its gonna die but it doesnt. what is the common cause of this. and also I notice when I press the brake the rpm goes back to normal. and I also hear a click noise on on the passenger side engine bay when I try to start the car. and another symtom is when I press the brake and turn the ignition key it just turns over and when I let go of brake it starts.???By the way this car is an automatic.
Idle is less than 500 rpm why?
Recheck your wiring. I forgot this happened to my boys escort I forgot what we did to fix it except his shit was standard lol.
Do you have any CEL codes? Does your speedometer work? When I replaced my Vehicle Speed Sensor (VSS), my idle went from ~500 to the standard ~750.
Good luck!- Ghosty
WTB: MAP sensor (2+bar), IAT sensor, ECU & dizzy harness plugs... PM me!
FS: coupe window rain guards, f22a6 intake & ex mani, cams, PT6 ECU, valve cover, dizzy caps, OEM fogs... PM me!
Originally posted by aznpnoyraceronly when you step on the brake sounds like the caliper is loose.
