H22 in but no Gas
    H22 in but no Gas
    Got my H22 in and it cranks but im not getting any gas at all when I turn the key I cant hear the fuel pump, I know its not my main relay cause Wagalud put it in his car and it started right up. When I turn my key the CEL light comes on but its dim and the main realy keeps buzzing but when I unplug the small harness on the right side of this pic, the CEL light up comes on complete and stays on and the main realy clicks on. Whats going on?
    [IMG]http://www.****.com/pics/f22/4%20copy.jpg[/IMG]
    Will's Accord
    i think there is a fuse for the fuel pump, did you check that?
    Members Ride
      I checked them all, could it be one of them big fuses under the hood, you know the big ones you cant see through.
      Will's Accord
        those are relays, i think its like four of them, but no those are not for the fuel system.
        which harness are you using on the h22, did you use the accord one?
        Members Ride
          Yeap, just added the VTEC wires.
          Will's Accord
            This might be a stupid question but is there fuel at the rail and such?
              It could be, cause it was working befor, cause I tryed it when the motor first got in, but i had to get another tranny and now it doesnt work.
              Will's Accord
                What goes to wires that are on the small round connector on the passenger side of the CB7, im talking about the 3 big one's that we unplug for the swap.
                Will's Accord
                  Thermoground?
                    Originally posted by wrichards2005
                    Thermoground?
                    Come agin
                    Will's Accord
                      Well if it cranks that gets rid of the thermo ground. Thermo ground wouldnt let the car start but it would power up. I guess you can try testing your fuel pump but prob something isnt hooked up? As mentioned checking fuses would be a good idea. Is there fuel in the tank? lol
                        the ground on the thermost housing, on the bottom of it
                        Members Ride
                          how long was the battery sitting? have you tried charging/jumping it?
                            yea I got gas lol and i checked all the fuses but ill look agin.
                            Will's Accord
                              the battery is fine, turns over with no problem. The check engin light goes dim until I un hook the connector thats in the image above. I wish I knew what thoese wires are for, its so many.
                              Will's Accord
