quick update
so i had the guys that did my swap fix the engine and it drives A LOT smoother and all that good stuff but im still having VTEC problems like itll engage stage 1 vtec at 4500 and then it still bogs at 5 then itll go to 7500 but check engine light will turn on but when im passed 5000 vtec isnt cracking and i have these options to choose from to be the PROBLEM
ps we checked the vtec solenoid and it turns off and on when you apply a battery current to it so it DOES work
1. NOT enough oil pressure so VTEC isnt able to open up ALL THE WAY or i need new oil pressure gauge, new oil pump
2. ECU is FUCKED and need a P13
MAYBES,
NEEDS-
new enjectors
new o rings
ANY feedback would be great
thank you
MAYBES,
NEEDS-
new enjectors
new o rings
thank you
