5 miles a gallon? .... 13 gallon is full.. 13x5= 65 miles till empty. i'll SHOOT that bitch.
Swap finished..ran into a prob!
hook up a fuel pressure gauge to your fuel filter and see if it drops in pressure on start up, if its does its your Main Relay again.....its common to have main relays fail, i've already replaced mine 2 times since i bought my accord 1yr and half ago.....Last edited by ehulst; 09-17-2006, 02:02 PM.93 Accord- SOLD
94 Civic- F22a1 Swap, current DD
Originally posted by d112crzywhy dont you guys just solder it? go get a cheap soldering iron from sears with some solder wire, and go at it. it takes like 5 mintues to fix.
Are you talking bout the ignitor switch...cause I already fixed the main relay yeah it took like 5mins to fix cause I know how to solder already.
Car audio classifieds...
http://www.caraudioclassifieds.org/f...ferrerid=12120
Youtube page http://www.youtube.com/user/blackoutt334?feature=mhee
BUMP...my car won't start I got another ignitor new fuel pump relay new cap I got fuel pumping in the lines...still the car turns over its not getting a spark..do you think the wires are bad?
He was talking about the main relay. Pull it out it controls the fuel pump and builds pressure in the fuel system.
I'm sooo crazy I feel so dumb the connector that goes to the dizzy,when I took it off of the old motor I lift a piece suck in the connector that prevented it from being pushed in all the way therefore not making a full connection.After we did that the car started up first time first try and it runs and sound real strong...I'm ready for my p06 now!!!
Thanks guys for you help!!!
