F22B DOHC Swappage (Headswap)
    i will be running the same swap but i will be running 450cc in prep for the turbo
    ~Nick~
      Godd it feels like i've been waiting forever for this clutch, and I ordered it late last week. Haha I just wanna drive this fucking thing. It's been almost a year? It's gona be sooo different, and so much faster.
      I removed the p/s, a/c, cruise, blower motor, a/c evap core, heater core, all back seat panels, backseats, trunk panels, and all the un-necessary shit.
      PS. And as for those 450's I wont use those until i'm turbo ready. Don't want to waste more gas then I have too?
      My Official Vouch Thread
      MY For Sale Thread!!!
      Recent Members Sold To:
      ALOW1, TheNextAZN
      Members Sold To (Vouches):
      ALOW1, Phempa, hpaccord91, aznsyco84, 93EXaesthetic, civic_90_08, wrichards2005, SuperTuner12010, JDM_EJ, Ralphie, cooneyb81, HondaFan81, quakerjoe, tanNn2koo, 91Accord-LX, JARHEAD293, TheNextAZN, (TONS MORE)
        Ahhh I Got My Clutcchh!!!!!! Pics In A Minute!!!!
        ALOW1, TheNextAZN
          YAY!!!
          ALOW1, TheNextAZN
            That is way cool. The head is so much like an H23, but it matches your bore size and the combustion chambers are deshrouded compared to the H23.
            hold on to your butts
              I would assume if you just swapped a stock JDM F22B head on stock F22ax block that H23 injectors would suffice your build. I don't really see anything that would say otherwise, unless you have other modifications up your sleeve?
              Anyhow, if you have an aftermarket flywheel your installing, make sure it has the ignition timing marks, if not make your own NOW before install!!
              Also, did you get a H23 or JDM F22B distributor assembly?? I didn't see that on your list. I'd get a new dizzy o-ring, new camshaft seals, replace your front engine seals (crankshaft, camshafts, balancer shaft seals, retainer for balancer shaft seals if needed). I'd also replace the rear main seal and put new oil pan gasket too, but that's just me New valve cover gasket kit as well.
                1. No H23 injectors, only others I have is 390's so i'm using them.
                2. No lightened flywheel, using stock for right now.
                3. I have the JDM F22B Distributor w/ a new cap(custom made for external)
                4. My block only has 35-40k miles so it'll be good for now. (Everything looks good and is in awesome shape)
                5. Got new valve cover gasket
                Thanks for the heads up man, but the only time i'll replace all these is when I have all the money to do it at the same exact time. Pry won't be for awhile but i'm not planning on beating the fuck out of my car just yet. That'll wait. I just want to drive.
                ALOW1, TheNextAZN
                  when i swapped out my injectors and put on the jdm f22b injectors, the car runs smoother now...
                  oh yea what ecu are you going to be using with that 390cc injectors? chipped ecu mayb?
                    My stock 5spd P39
                    ALOW1, TheNextAZN
                      390cc injectors with p39 ecu? kool let me know how it runs with them injectors
                        You said that in a kind of denial way. Like it wouldn't work too good??
                        ALOW1, TheNextAZN
                          id imagine they'd run rich, since h23 injectors are no where near 300cc.
                            What size are they?? Stock F22AX's are only 240's.
                            ALOW1, TheNextAZN
                              everywhere ive read they are either 240 or 260cc. i wouldnt doubt any one of those sizes tho. the fuel maps for f22 and h23 are very similar.
                                if it was me, i would use my chipped ecu with that 390cc then tune it with UBER...... BUT thats just me tho
