Installed my motor last weekend and I have to admit that I'm extremely let down by the performance. it feel about as fast as my f22a6 with delta cam, i/h/e and mrx ecu. I'm thinking that it's a timing issue. I tried setting the timing last night but could not see the mark at all on the flywheel. I'm not throwing any codes and I've tried running my p13 ecu and my chipped p06. Neither make a difference. The motor is super clean on the inside and the injectors are clean. Any suggestions as to what it might be that's making this motor feel sluggish?
Any suggestions would help.
The compression test before I put the motor is was fine accross the board but I will still check it again.
Also, when I was putting in thr motor, the h22 crank pulley looked shady so we stuck my f22 one on. Upon doing a search, I found that the f22 is a little bigger but people have swapped them on before. My alternator belt is tight but I don't think that would affect the performance at all.
The mods for the h22 are Type s cams and pistons, mugen header, and a huge nissan throttlebody that's portmatched to an h22 manifold.
