running way to rich, fouling plugs FAST.
    was it fouling the plugs to the point it wouldnt start? if so its not burning off the gas and its sitting in there building up, or the ecu didnt kill the fuel pump once it built up pressure and kept running. I dont know
      well at first it would start up fine, then it gradually got worse, and now it won't even start...
      OS^e
      1993 Honda Accord LX Coupe
      My Members Ride's Thread
      StickyDilJoe: "JDM may be a fad, but making your car look like shit... thats forever"
        if youre trying to start it constantly its gonna keep putting gas in there cuz..pull the plug and let it vent. The gas will evaporate through the plug holes..i dont know how long this will take. you dont want any gas getting back down into your oil pan. i just had a similar problem just this past week. i could here the gas drippin into my oil. not good. try to vent it or crank it by hand with the plugs out might help push the gas out..neverknow..sux man!
          just pulled the dipstick and there is a hint of gas on it
          I guess tommorow I'll drain the oil and change it all out
          OS^e
            sorry man that sux...guess i was to late
              u may wanna pull the valve cover too case you got gas up in there..up to you
                hmm, phat is using the same map and he's running perfect.
                  Hmmm you try swappin out ECU's and see whats up?
                    nah, I dont have any other ECU that will work for it, but I'm beginning to think its not the ECU
                    OS^e
                      oh and the gas problem isnt that bad, I think simply changing the oil will get rid of it (you can barely smell the gas on the dipstick... and the longer I wait, the less noticeable it is)
                      OS^e
                        use your f22a ecu and see if it will start it. It should run decent. no vtec tho
                          I've already done that, and can't get it to start... I'm gonna check later today to see if its got any spark
                          OS^e
                            So its not even starting with the p28???? that is why you are fowling the plugs.
                              well, I think the reason its not starting right now is because the plugs are to far gone. Im gonna go buy a bunch of plugs to day so I dont have to worry about that
                              its acting as if it isn't firing so its either a: distributor related (dont think it is) or b: fouled plugs.
                              OS^e
                                True. That would be the main causes. Your running the internal distributor right?
