Hey I have a question what setup can you use that will clear the hood without a problem? I see some guys have different setups on there F22B's and alot are really low on the block. That is the setup I need Just picked up a Carbon fiber hood and it won't clear the pump bracket like my stock hood did.
F22B DOHC Steering Pump
Try grinding down the bracket a lil but i doubt that will help. How much clearance are we talkin here? Why dont you just run no PS i mean its only a bitch when your still....My Accord PS pump hits my hood i hate it it turns out it was my high press hose and i solved it by taking a rubber hammer and hitting it a lil lower.
Originally posted by ZigenBallZThe F20A DOHC pump uses the same hose as the F22...
I couldn't use the SOHC bracket or pump with my CF hood because it wouldn't latch let alone allow me to pin it down...
So which Bracket and pump should i use or ask for?
Originally posted by oneoffaccordi used my accord pump with the bracket and aem pulley. i cut off the left flange/bolt and bolted it up using the other two bolts. then i put the pump all the way down and used the smallest belt that would work.
I have no donor car....
Originally posted by cb9tunerguyhere is my pic. everything fits like it should be factory
The CB9 has been reborn into a CB3
Members Ride - see my cb3 here - DOHC powah
Check out my JDM F22B swap
Watch my CB7 video
