well im not done yet but heres my progess so far also in the very last pic there is a harness which i think is for the a/c so do i not need that if i dont have a/c let me know
My wire tuck
nice good start but there is a lot of work ahead. are you doing a full wire tuck or a partial wire tuck. another member on here (starkrice) did a full tuck but it involved getting rid of the heater core to make room for the fuse box and other wiring which were all placed under the pass side dash. having the A/C removed also enables you to pass the wires through the firewall where the lines usually would. the holes are pretty big so you can do wonders.
and yes IF that's the harness for the A/C and you don't have A/C, you should get rid of it. i like that ground box you put on the outside of the frame. how did you get it through that hole?! hehe . keep us updated man!
Originally posted by timmy0toolnice good start but there is a lot of work ahead. are you doing a full wire tuck or a partial wire tuck. another member on here (starkrice) did a full tuck but it involved getting rid of the heater core to make room for the fuse box and other wiring which were all placed under the pass side dash. having the A/C removed also enables you to pass the wires through the firewall where the lines usually would. the holes are pretty big so you can do wonders.
looking good man.
that harness is for the ac and 2nd fan(ac and/or automatic tranny fan)
what i did to hide some wiring for the engine itself is to take it off completely. reloom with new electrical tape and make it tight as possible.
after that just hide the rest of it behind the block and under the I.M.
Originally posted by excalibur02^^^ yea thats ac shit. just unplug it and unbolt the 10mm that hold down the solenoids (round things) and then with the open plug on the wiring harness just tape it up so that it wont get water or junk inside.
IYAHAHHHN! it's the "whale dick" intake! Well thats what it's refered 2 on Honda-tech Finally I get to see this in a CB7. How does it feel man? Is there a noticeable difference in acceleration compared to the intake u had previously? Does it sound louder than a regular shortram? People have said it's almost comparable to a Aem V2 or Type-S intake since it has a semi fatter mid section. Good shiet!I need a custom turbo manifold built....
707 NorCal NinjaZ
Honda Twincam Motorwerkz?"I am the Yakuza CB7!"'92 Accord Sedan SiR
