need help??????????/
This topic is closed.
    can anybody tell me where the knock sensor go on the f22b dohc. pictures would be a big help. please anybody!!!!!!!!!!!!!!!!
    SOLD-->10-09-06
    MY 2000 PROTEGE
    MY OLD CB7
    THE SWAP
    MY COROLLA TYPE-S
    it doesn't get one. compression was low enough and it was never given a KS - and if you are correctly running a P39 it doesn't require one, since that's the stock ecu for that engine.
    . if you have a different ecu - (such as P14) please search "knock sensor wiring" or "F22B Knock sensor" and you will get pages on pages of info - if it's not a DIY, then you might try going to the last page of results and checking oiut the earlier posts first - they are often the most informative.
    also you already have this thread posted and its titled "F22b dohc question"
    please bump that thread for more info pertaining to the same issue, rather than starting a new one - thanks
    breathing is deadly underwater...
