no..... you said destroked h22.. which its more than just that... shorter stroke and smaller bore
f20b dohc
Originally posted by fizzbob7
you mentioned the cams being larger than h22a cams......that's manual only, correct?
why do the auto f20b's have 180hp at the flywheel.....i HEARD it was the tb, cams, and ecu...........you know for sure?
and why you building an f20b instead of an h22a?
just because they're not as common?
From what I've gathered from talking to him the reason the auto has less HP is because of a more restrictive TB and Intake manifold. Probably to hlp it build more torque since it's Auto.
