94 h22 swap/91 h22 swap?
    I have do a H22a swap into a 94 Accord and was wanting to what if any the difference is from the 94 and a 91 Accord when it comes to swapping the H22a/ Thanks for the help
    there are a few differences but not many. just do the swap like you would do the 91 accord. then after that figure out what needs to be added.
      I believe the left side motor mount doesn't work with out lots of tweaking. You also need to swap the 6 and 11 on the ecu and wiring is a little harder if you've never wired anything before. Hasports sells a plug and play wiring harness and the motor mount if you want to go the easy way... Also if the motor is jdm you need either a older accord fuel rail or a prelude one as I dont remember the stock 94 one working... I could be wrong. The exhaust flange needs a little modding if its jdm but other than that it should be the same as doing a cb h22 swap.
      Oil leak?What oil leak? That's just sweat from all that horsepower!
      Applied knowledge is power!
      NITROUS FOR YOUR BODY
      BIRTHDAYS ARE JUST AROUND THE CORNER
      registration is free
        the tranny mount doesn't have 2 be change like the 4gens do bascially the all motor mounts are exact drop in's reason being the 5th gen accord's and 92-96 prelude have the same exact platform
        H23vtec
        Kee Built/Tuned
        87x95 11.7 compression, custom h22 intake, minor head port polished, 70mm tb, 3inch cold air/3inch vstack, stock cams,ebay header with 3inch collector,3inch exhaust.
        9.0's at 81mph in the 1/8th mile ohh how i miss my baby.
          I am wanting to do a 91 accord now. Sold my old H22 but thinking about getting another one but now thinking about h23/f22b. But no sure yet. Just want to make sure that it is easier in the 91 than it was to do the 94. The 94 sucked to swap.
            trust me.. its easy. and this coming from someone who never swapped a motor before until i did my conversion. also, i previously had the jdm F22b; not bad, but better off just going with the H22.
            5.6L V8 32V DOHC
            JDM HERITAGE - US BUILT
              its the drivers side mount. you need to shave like a half inch off it. you also need to custom make the downpipe, since they dont match up like 4th gens do. other than that, this guy is pretty much spot on.
              -Mark-
              CB7
              CD5
              And if i could swim I'd swim out to you in the ocean
              Swim out to where you were floating in the dark.
