Chipped ECUs *Help needed*
    Originally posted by westsideaccord
    ok so I pull a h22a out of 2000 prelude auto and as long as I dont hook up tcu it will work(pending I change those wires in the harness?)? And I can use my f22a manual tranny and driveshafts??? I am the grasshopper! always learning!
    thats pretty much it my f22b dohc used to be an auto (as i can tell from the presence of a flexplate) - we just took off that plate to mount the new flywheel, clutch, and pressure plate
    BUT MAKE SURE TO USE THE BOLTS FROM YOUR F22 MANUAL FOR YOUR NEW SETUP - The auto bolts for the flex plate are a smidge shorter than the ones used to bolt on the clutch and pressure plate - youll need the bolts from the engine that had a manual tranny to fdit everything on snug and right-like
    oh and have fun with those flex plate bolts... you need a 17mm 12-pt socket and a decent impact gun... i know i had a blast
    and yeah, as for your computer, just dont hook up a tcu and your car "assumes" manual by basically not knowing any better (if that makes sense) ... and thats assuming you have all the obd conversion stuff done and all (which i dont know a ton about, since its not a problem i have to deal with myself)
    ~*~Cass
    breathing is deadly underwater...
