hey i have an h22a in my 90 accord, what is the easiest way to change my trans? pulling the motor out or dropping it down? also besides the stock trans and the trans for the h22 do any other transmissions fit? trying to go the cheapest yet best way possible
easiest way to change trans?
drop the trans, leave the motor in the engine bay.
Per hemls (Manual TransAxle):
1) Disconnect Battery Terminal (Neg 1st, then positive, then remove battery)
2) drain trans fluid
3) remove battery base and base stay
4) remove air intake duct and filter
5) remove intake control vaccum tank and bracket
6) disconnect starter cables, then remove the starter motor
7) disconnect backup light switch and trans ground cable
8) remove wiring harness clamp
9) shift tranny into reverse (MANUAL)
10) remove (shifter) cables and brackets
11) disconnect vehical spedo sensor and remove from tranny
12) remove (clutch) slave cylinder
13) remove dampner mounting bolts and raise clutch dampner
14) remove rear engine mount bracket stay
15) remove cotter pins, ball joint nuts, then seperate ball joints and lower control arms on both sides
16) remove right (passanger side) dampner fork
17) remove right (shifter) radius rod
18) remove driveshaft and interemeident shaft
19) remove center beam
20) remove front engine stiffner and cltuch cover
21) remove intake manifoild stay
22) remove rear beam stiffner
23) remove three rear mount bracket mounting bolts
24) put floor jack under trans just enough to take weight off mounts
25) remove trans mount and bracket
26) remove the two upper trans housing mounting bolts (?? can't even tell where these are by the picture. looks to be just below the dizzy)
27) remove the three lower trans housing mounting bolts
28) drop trans outta car =)
By the way, towards the end, just remove the bolts that hold the tranny to the engine =)
good luck.2DAO (2 Door Accord Owner)
JDM H22 DOHC 200/161 2.2L
My members ride: http://www.cb7tuner.com/vbb/showthread.php?t=20385
for the record, with the h22 in the accord you cannot drop it down enough to get at the trans without pulling the power steering pump off, it hits the cross member, so i just pulled my whole engine out and took care of the trans and took the power steering pump off at the same time, btw does anyone know what size belt to use on the pulley without the power steering pump on?
Originally posted by pat nubenfor the record, with the h22 in the accord you cannot drop it down enough to get at the trans without pulling the power steering pump off, it hits the cross member, so i just pulled my whole engine out and took care of the trans and took the power steering pump off at the same time, btw does anyone know what size belt to use on the pulley without the power steering pump on?
im not talkin about the cross member that goes from the front to back, im talkin about the cross member that goes from side to side, the one that you have to notch in order to make to the header and down pipe fit, the power steering pump hits it, so thats why i pulled the motor, it just made things alot easier, plus now i can pull all the un-needed pulleys and belts off
