F22b> No Fuel Or Spark?
    i just got my motor in an hooked up. ive converted to internal dist. stuck a fuse through the yellow wire and the yellow and black wire. Im not gettin any spark on the distributer. the engine cranks but doesnt spark and thiers no fuel going through the fuel line eitehr? anythin that coould cuase this problem? im open to any suggestions;
    does the cel light come on in the dash if not you did not hook up the ecu groung under the thermostat housing, that or the main relay, can you hear a relay when u turn on the car
    fuck the bitches that stole my car jan/1/2006@7am from montesano wa updated: The Warrens from Malone Wa were found guilty for possesion of stolen property in the 1st*and were ordered to pay $2489.69 in restitution, only cause the shell was not found
    R.I.P.
    Vouches from: Snailin91, Caution, 2G6, Jdmf23accord, Boosted_StinkyNuts
      how do you know there is no fuel being deliverd?
      People I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
      Mk3 Supra Member #2
      Originally posted by DarkShadow707
      The world needs to be reset.
        yeah dude all the lights come on and the radio and such and it cranks
        but when i have the fuel line disconnected thiers no fuel squirting out when i start the car and no spark from the spark plugs? i have no check engine light either. what does a relay sound ike
          ECU maybe. It controls both. A bad ECU wont give you fuel or spark. And please do not tell me this is the reason you are getting rid of your CB7.
            swap the ecu for one that u know works and if no go i am positive that is a ground of main relay i had the same problem
            R.I.P.
