Here's the problem guys, after the h22a swap I notice that after I start the car and drive there's a weird noise coming from the passenger side engine comparment (sound like a vacuum line leak or something rubbing not too sure how to describe the noise ) The noise stays on while I drive for about 2 minutes, the noise stop then the ABS light appears on the guage and stays on. The brake works fine but i guess there's no ABS any ideas of how to fix this problem Thanks.
Weird Noise Then Abs Light After Swap
That noise that you hear is the abs motor. My car does the same because my right rear sensor is bad. And the ABS light can come on for several reasons. One of the sensors may be bad or needs to be cleaned (if there is tooo much dirt on it then it wont work). There may be air in the system. Could have a bad relay.....etc. Take it to a shop or someone that can diagnose it for you to see what the problem is."The Fresh One"
Thanks for the respond . This problem did not exist until after the h22 swap, the ABS was fine before. Maybe the mechanic forgot to plug something or messed it up accidently . I'm taking it back to the shop this week to get the ecu install, we'll see what happen I guess. Anyway thanks again.
