distributor question for f22b
    so i have to buy a dizzy and when i type it in on ebay it only gives me dizzys for h23/h22 vtec dizzy ext coil so will this work on h23 non vtec i dont see why it wouldnt but on the appliction list non vtec isnt there
    www.2camcrew.com
    also will the single cam crank pully work sense there basically the same block
    www.2camcrew.com
      im kinda drunk right now, but on one of the legs of your dizzy it sasis the number of the dizzy, and if you call distirbutor king he can get jdm dizzys if you wanna get internal one agin. if not then you have to convert to external h23 one..
      good luck.
        no i want an external so i was seeing if they will work because they are vtec and f22b is not and i dont have a dizzy to get the code off of because i have no dizzy and i want external coil
        www.2camcrew.com
          when i had the jdm f22b dohc, i bought a dizzy which was for the usdm H22/H23 and it worked fine. even after i hydrolocked the f22b, i'm still using the same dizzy on my H22
          5.6L V8 32V DOHC
          JDM HERITAGE - US BUILT
            so the h22 external coil will work
            www.2camcrew.com
              same part # for the H22/H23 dizzy
              5.6L V8 32V DOHC
                thank you
                www.2camcrew.com
