alright i have a few questions my engine is in but these few things are holding me up. my gas line in my care is on the passenger side but on the jdm h22a it hooks up on the driver side and it will not reach over their. so what should i do what kind of high pressure line do i need to get? and for the ac i used my stock compressor a prelude bracket what kind of ac belt do i need the prelude, accord , or custom. and what do i do about putting the wires in the ecu pins how do i get the wire in them
h22a swap! high pressure gas line?
Take the fuel rail from the f22 and place the injectors from the h22 in it but make sure you change the o rings .
Originally posted by RidnLowalright i have a few questions my engine is in but these few things are holding me up. my gas line in my care is on the passenger side but on the jdm h22a it hooks up on the driver side and it will not reach over their. so what should i do what kind of high pressure line do i need to get? and for the ac i used my stock compressor a prelude bracket what kind of ac belt do i need the prelude, accord , or custom. and what do i do about putting the wires in the ecu pins how do i get the wire in them
*since your using the accord a/c compressor(i have the same setup), you would need to use the accord Ex 5-rib belt.
*read the sticky! scroll down and it'll show you how to work with the ecu wires / pins
COMPLETE SWAP THREADLast edited by PRIMOCB7; 06-15-2005, 09:19 AM.5.6L V8 32V DOHC
JDM HERITAGE - US BUILT
