hey anyone got any information on the f22b swapping into my 91 5spd? im looking into purchasing an f22b motor only and need to know if it will directly swap onto my motor mounts,tranny, all the hoses,ecu, and i read something about the distributor and fuel rails might have to go? any information is appreciated. thanks
f22b swap
dont let phat see this thread....
yes, direct swap. search for the details. heres one for starters:
http://www.cb7tuner.com/vbb/showthre...ight=F22B+swap
everything from ur old motor is swapable. f22b dohc drops right in with stock f22ax mounts. the distributer on the f22b dohc i'm not sure b/c mine is a 93 cb7 and i convert it to an external using the h23 distrubuter and ran the h23 ecu. i guess you could stick with your stock ecu and run the distrubuter that comes with the motor b/c your car is already running an internal distributer, but later you will have to get another ecu, wheather a h23 ecu or the f22b dohc ecu.........=my idea of classic JDM
to my car page
Originally posted by k-martdont let phat see this thread....
When it comes to F22B's... he is like the NSA... he has a network setup to intercept and flag any and all comments, references and questions regarding it...
he probably knows you're going to post about it before you even hit submit...RIP Lifsatrip7
Originally posted by jdmcordhow do u know if its external or internal coil? and what does that mean exactly, srry for the noob question.5.6L V8 32V DOHC
JDM HERITAGE - US BUILT
