F22 block F23 vtec head
    does any one think that ill have valve clearence problems when i put togather my motor? At first i though it was a f22b1 head, but it turns out to be an f23a1 head. the f23a1 has 86mm Bore and 97mm Stroke, and yeilds a 9.3:1 compression raito. should any of these differences hurt my motor? what would i have to do to bore it out to 86mm?
    Turbo f22a/f22b vtec
    do exactly what u just said.. bore it out if u want to 86mm .. then u could use f23a pistons on f22a rods.. i believe the wrist pin location is the same.. look into it thou.. honestly for the trouble of making ur f22a into a f23a.. why not just GET a f23a.? 86mm iron sleeved 97mm stroke accounts for gobs of torque.. and i believe the f23a5 the DX version has like 8:6:1 compression which would rawk under boost
    Praise The Lowered...
      i checked all the oil and coolant gallies and they all lined up. there's nowhere it can leak like the f22b head swap. i was just wondering if i bolt this head on will it work?? the reason for this head swap is cuz i have a kick ass manifold. I really wish i could go with a a6 though.
      i also like that the f23's have roller rockers too.
        just found out all of the 98+ accords have 9.3:1 compression. the only difference is that the dx's are ULEV (ultra low emissions vehicle) which drops the hp 2-5 and the torque 17
          hmm.. ha.. then i guess its the hybrid that drops the compression.. my bad.. lmao!!
          <hybrid freak...
            how much do you think it will drop my compression. my knowledge in hybrid accords is small. since this drops my compression dose this mean i can boost more? also donsent lower compression = more torque?
              lol fuck.. i dont wanna turn another sohc owner into a dohc owner.. im not trying honest..!! im not!! lol..
              if the stock compression is 9:3:1 then the number i getting of 8:6:1 is after a h22a head install f23/vtec basiclly...
                ok now al i need is a valve cover from a 98+ accord. what could i use for a base map on this motor? BTW WiKKeDV16.......... You have been more than helpfull. thank you
                but i still love the simplicity of the single cam.
