ok I let my car sit for awhile cuz I couldn't get up the funds but I Just bought a chipped/tuned ECU for $200 thinking that would fix my car but It sat for awhile like a year since I needed new ignition switch, fixed that, it drove for 20 mins then died at stop sign then started and died on way home had to be pushed home....and I had you guys do my wiring awhile back and my car ran good but now it needs you guys again!!! IDK what 2 do but Im not SELLING IT. I Wanna drive it when its running right and ive never been able too, had car for years.. help.
JDM H22A needs HELP Getting back on road!
Okay I got a question now how did the car die. Did it die at idle or chug out and rolled then died. First check for spark and the spark consistency cause it could be a bad distributor,distributor cap or coil. Last but not least that fuel pump is a problem and the fuel pump module which is way up there just about the kickpanel.
Originally posted by h22sparkle View PostOkay I got a question now how did the car die. Did it die at idle or chug out and rolled then died. First check for spark and the spark consistency cause it could be a bad distributor,distributor cap or coil. Last but not least that fuel pump is a problem and the fuel pump module which is way up there just about the kickpanel.
did they put on the correct distributor?
or did they just start replacing parts?
my neighbor down the street had his car (Toyota Camry) shut off on him about 2 blocks from home, it was towed by AAA to one of their shop where the "mechanic" (and i use that word loosely) said that it could be the alternator or the starter or the battery or the computer or the distributor or the igniter or the fuel pump ....etc etc
he had the car towed home and let it sit for a few days in his driveway. he was considering donating the car and checking out new cars when i suggested to look under the hood himself and look at the wiring as best he can. He asked me to come over because he had found a few broken wires. I told him they were chewed on by a rat and we spliced them back up ,checked the fuses and found the ECU fuse had popped, replaced that and Lo and Behold the car was idling nicely. As a last item we replaced the negative battery cable because it was looking bad AND retightened all the Grounds. He is still driving the car today (3 months later)
have you gone through all your grounds and wiring connections to make sure they are all tight, also check your main relay, mine was doing the run now not later thing on me
If your harness is obviously all jacked up then get a new harness and eliminate that issue from your diagnostics. No point using bandaids on a gun shot wound. Follow testing procedures listed in your manual systematically and this will lead you to an informed course of action. If you dont have one already then invest in a multimeter.
Also pumps don't go bad that often.
Harness info available here
http://www.cb7tuner.com/vbb/showthread.php?t=5423
and just in case here is a link to a prelude manual available online. This should cover the h22 side of your issues.
Prelude Service manual PDF download
http://prelude.openbarr.com/manuals/...92-96_lude.pdf
also sent PM.Last edited by Tishock; 10-08-2013, 02:19 PM.
Originally posted by tishock View PostIf your harness is obviously all jacked up then get a new harness and eliminate that issue from your diagnostics. No point using bandaids on a gun shot wound. Follow testing procedures listed in your manual systematically and this will lead you to an informed course of action. If you dont have one already then invest in a multimeter.
also sent PM.Last edited by xheartlesskingx; 10-14-2013, 01:20 PM.
just spoke 2 mech
He said that he doesn't think its the Fuel pump. He said the car isn't getting Spark and maybe its a wire short and that they tried everything..??? New Distributor and idk what else he tried so I asked if I should get New Harness and he just seemed to push that under the rug cuz hes a quick fix mech so idk why he has a job doing like 30cars a day!! lol. ANYWAY what HARNESS guys and can I get one from Junkyard or LKQ or something?
You really need to either find a new mechanic, or start reading.
We can't spoonfeed you info when you're not actually going out and troubleshooting and giving us reliable information.
So i'd suggest you get a Haynes manual and pop your hood and start checking things.
Fuses?
Wires?
Is the fucking battery connected?
Like really dude how can we help you if you don't even know what's going on?
the fuel gauge is getting the signal from the fuel level sensor NOT the pump, so you cant know if the pump is bad by the needle on the dash.
If you cant hear the pump run then you could check for fuel pressure at the fuel rail with key on, this will determine if the pump is working or at least getting power.
why not check the main relay or the ground to the pump?. had a lose ground under the back seat. anther time it did that it was the main relay.Last edited by coltonfrostcb7; 10-28-2013, 01:28 PM.
