ESP.net CB 90-93 Accord/94-97 Accord Auto to 5 spd Trans Mount w F22 90-93 Pattern
    www.ExplicitSpeedPerformance.net
    Explicit Speed Performance
    Email: ExplicitSpeed360@aol.com
    AIM: ExplicitSpeed360
    Phone: 1-360-866-8530 Monday-Saturday 10am-5pm
    Ask for John
    Hello, guys we just came out with the CB 90-93 Accord Auto to 5 spd Transmission Mount for use with the Typical F22 90-93 Transmission Stud Pattern. Before you had to swap the rear 2 studs into the H pattern. Some of the transmissions do not have the H pattern available. So we made the F22 Pattern.
    We have a kit for either 90-93 Accord or 94-97 Accord that will be using an earlier 90-93 Accord transmission.
    Our replacement/aftermarket motor mount kits are made out of 1/4" steel and are made super strong. Built to last! We use 70A polyurethane for the inserts. Choice of Red or Black insert colors. These motor mount kits are much stronger then the OEM piece and the polyurethane inserts will limit the engines movement and improve handeling and help deliver more power to the ground. Simple bolt in experience. Toss our your old worn out britle OEM mounts or OEM poly filled mounts or OEM insert mounts. Adding poly filling and inserts to the old brittle OEM mount is just putting a bandaid on it. Your still using the old brittle mount and rubber middle. Toss it out and use our much stronger complete polyurethane mount.
    I received my Auto to 5 speed mounts a few days ago, and WOW! these are some nice mounts!! Thanks guys for making quality parts!!
    Cappuccino Member #9<--- click for thread
    ^click for MRT^
    CB9 MRT-R.I.P.
    Coupe MRT
      when did you order them? like 5 months ago?
        I ordered them on Feb. 12, 2013
        ^click for MRT^
        CB9 MRT-R.I.P.
        Coupe MRT
          sweet the ball is greased and rolling..i put my order in the 14th.
            I just got the mounts in the mail 2 days ago, they are nice mounts.
            I took pics,
            H22/23 pattern. I'm using an H23 transmission.
            It would be nice if there was a write up on how to replace the timing side mount. I'm sure its not hard just would be nice.
            The instructions said not to overtighten just to make the material squished or else they may crack. Just some heads up there.
            “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
            ― Jeremy Clarkson
              sweet..that means i should be getting mine soon. their powdercoater sure knows what theyre doing. that looks excellent. I cant wait to see my wrinkle black warez
                I ordered mine on April 21st and got them on the 28th of May, so it was a little over a month.
                We're lucky that that man makes such mounts, they are the only ones for our F22a engines. Thank God for that.
                What color did you choose? I think the gold is beautiful.
                ― Jeremy Clarkson
                  oh wow lol i ordered valentines day, h22a w/ h22 auto mount set, traction bar with torque mount, alternator bracket and front and rear strut bars..all in wrinkle black with black poly
                    That's crazy its taking so long, like he said everything is homemade and he has a lot of orders. I did ask the guy (John) if he could get them done sooner and he said he would. He was true to his word.
                    But do you think the production quality was reduced because of that? I have a question about that in my video.
                    Is it supposed to do that?
                    ― Jeremy Clarkson
                      That's crazy its taking so long, like they he said everything is homemade and he has a lot of orders. I did ask the guy (John) if he could get them done sooner and he said he would. He was true to his word.
                      well from i read around his old man is the master welder and he isnt doing so well, at 12 weeks i called and was told its race season call back. 14 weeks i call same thing..18..same..whatever were at now i called last friday. mounts and tractions bar are out for coating (key parts to get this shit going)..so yeah I paid it all the day too I ordered lol in feb
                      your mount..thats just a little warpage from the heat when they welded that box to the plate, when its bolted down it should be fine.
                        Okay thanks for answering my question.
                        So what is it that so great about these beefy mounts other than the fact they're conversion mounts, will they make my car faster or handle better? I know they will last much longer.
                        ― Jeremy Clarkson
                          them with the traction bar is putting all the power to the ground, minimal motor movement. some company makes some billet mounts about the same price less a couple mounts. Explicit's these i believe are all tig welded in a jig, the bushings look a lot bigger then the billets, probably easily refurbished too..made in usa supporting someone that gives two shits about this niche market plus its custom, like mine I needed an auto H trans mount no problem..a rainbow of colors for powder coating, and im sure if we can break stuff a call and a new one will be out fast
                          the proofs in the pudding and hype burns out quick..so we'll see
