hey i have a 1995 accord ex coupe. I want to change it to 5spd can someone tell me all the parts i would need to do this swap. thanks
5th gen auto to 5spd swap
I guess I will be the first to say it because I had to hear it too....use the Search feature...it is your friend.
I have heard that you do not need to move the mount in the 5th gens but I could be wrong. If not then all you will need is:
Tranny
Shifter/Cables
Pedals
Clutch Master Cyl./Damper/Slave Cyl; all lines
There is more, like I said...searchProjectParty.net
Putting an end to the question, "What's going on tonight?"
"This generation has this universal sense of failure" - Kurt D. Cobain
CLUB 1320
My FOR SALE thread...buy my ish
everything should be the same except the reverse wires. But the principal is the same. Locate the reverse lights on the tranny, HELMS will tell you were. Then splice those wires into the reverse lights wiring harness off your original wiring harness. Then simply run those same wires from the plug near the ECU that went to the TCU to the where the old auto shifter was.2DAO (2 Door Accord Owner)
JDM H22 DOHC 200/161 2.2L
My members ride: http://www.cb7tuner.com/vbb/showthread.php?t=20385
