...My stock H22A appears to be running a bit rich. I have an adjustable fuel pressure regulator set to 30. Can anyone tell me what the stock fuel pressure should be. Is 30 a bit high...?
Did you remove the vacuum line and piug it when you were adjusting the fuel pressure cause if you didn't your getting a false reading
would this also apply to larger RC injector with spray pattern is optium for 43.5psi? OR it should not matter much and I should set it down to 32/35 psi.
Right now I run at 40psi at idle and 45psi at WOT but I do have the SAFC II to lean the bigger injector out.
90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate < 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
