Hey ya'll just wanted to confirm that after a swap from an auto f22 to a manual h22a, the axle I use is still the 93 accord axles. I can't remeber for the life of me if I had to get a prelude axle for that.
I hope you did the auto to manual conversion properly (either cutting and welding the transmission mount bracket, or using a conversion mount...) or else NO axle is going to work properly.
Yes, I got a mount and did it correct. I'm just replacing the passenger side axle, so it IS the MANUAL ACCORD PASSENGER SIDE axle that would be in there?
OK EDIT, found out part numbers are same for passenger side auto/manual axles.
