Which tranny for boost?
    Ok so I am building my Single came fully built for boost , now question is I have a chance to get a JDM M2B4 TRANNY (LSD) with hasport motor and tranny mounts for $800. Tranny only has 40k miles. Now is this a direct bolt on or will modification be needed? Post links if possible thanks!
    any f series or h series tranny is a direct fit
      h22 is the best one
      h23 would be a great all around tranny highway/city
      f22 would be good but long gearing
      this is my .02 cents
        on h trannys theirs a diy mount hole placement. you might want to look into that bro.
        RIP 4/23/12...lets not forget, the 88" Z31 turbo, are my dailys
          If you can get the lsd trans go with it. I'm curious to know which is really the best. To my knowledge, the rsx people use the five speed and not the type s trans for longer gearing. They stay in boost longer that way.
          Originally posted by Dr. Shuffles
          Prius? Fuck that shit. I can't afford those things. Why do you think I'm driving a Honda that's old enough to buy beer?
            as long as its not the atts H trans that is
            [COLOR="Magenta"]
              Or the f from the s2000.
                Ok thanks guys! Ima get it this weekend! I'll post pix up ASAP of it too!
                  @jewelproject, yeah man i was reading that, ima do that.
                  he texted me last night im getting it for $500 with hasport motor and tranny mounts, now thats a good deal!
                  i still need to pick up a H23 I.M, i am trying to find the thread for this but i cant seem to find it lol
                    If this deal is real jump on it.
                    The m2b4 is one of the top 2 best tranny for boost.
                    Mine held up good and the gearings are nice .
                    -->751 whp @ 27psi <--...Midnight Tuning <----
                      I'm getting it this weekend! So stoked
                        I thought u want longer gears for boost 2 ride out the entire rpm range.
                        I could've sworn I read that the h22 is to short that idly the h23 will b better for boost.
                          H2U5 or H2A5 if you are looking for long gears, but if you have the time and money then take 1-4 from an M2Bx and use an H2U5 5th gear .
                          The CB7 Collector.
                          Team Kindred Impulse Member #3
                          92 LX Coupe F22A1
                          2013 Toyota Corolla S
                          92 EX Sedan F22A1
                          Do you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
                            Longer gears are generally better for boost. You spend more time in boost, and less time shifting and respooling the turbo. Now, that depends on what turbo you're running, and what you plan on using the car for as well. Most guys that want drag performance go with longer gears, so they run the quarter mile with one less shift.
