first of all, thanks to autozone for actually stocking every single part i need...second, the guy that is giving me a discount for buying so much from them had an mr2 w/ lsd and jdm engine and he said on his the spline was diff so he had to get a diff. axle...the problem is, when i look on the back of my engine, there's a long shaft coming out of the tranny into a "holder" mount for the axle, then there is an exposed double step, which i assume is for the ring to snap into, or is this just half an axle that needs to be pulled and replaced? pics would help, but just letting me know which axles to buy will work...i thought u just used the 92 accord axles? i dunno what to do w/ this axle deal comin outta the tranny though...oh, and btw, starting the swap today!!!!
Help Please!! Axles Different For Jdm H22a W/ Lsd?
Originally posted by mayberry4thgenUSE YOUR ACCORD AXELS NO MATTER WHAT!!!!! it doesnt make a difference if you have lsd or not.....H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
Originally posted by mayberry4thgenno, dont listen to these guys. you use an accord halfshaft and axel....it wont workt he other way due to the fact that the lude halfshaft has a male adapter and the accord is female!!!!!use the ACCORD AXELS AND HALF SHAFT!!!!!!!!
if your car is a 5speed just use all of ur accord stuff(intermediate shaft and both accord axles) . if ur car is an auto and ur converting it to a 5speed and ur using an accord intermediate shaft, then u can buy and accord driver's side axle and use your auto passenger side one( if it's in good condition). hope that helps.
