h22 swap injectors not fireing
    just put h22 in a 94 accord and the injectors won't fire need some help/advice
    Out in the driveway building something
    im guessing before the swap, the car was running fine. if so, check your grounds to make sure they are in full contact to wherever they are attached to. also check the fuel injector resistor box..to see if any power is going to it; and if it is, check for resistance.
    5.6L V8 32V DOHC
    JDM HERITAGE - US BUILT
